Configure I-SID Monitoring
Use the following procedure to configure Fabric RSPAN (Mirror to I-SID) on the Backbone Edge Bridge (BEB) connected to the monitor station.
You cannot configure the source of mirrored traffic (mirroring to an I-SID) and the analyzer (monitoring an I-SID) on the same local device with the same I-SID offset. If you require mirroring and monitoring on the same local device, use standard port-based mirroring instead of Fabric RSPAN. Fabric RSPAN mirrors traffic into an I-SID of the SPB Fabric network and monitors traffic on the remote device; the network analyzer resides on the remote monitoring device and not on the same local device.
If you change the egress port or egress MLT for a particular session using a separate CLI command, it overwrites the existing egress port list or egress MLT.
Switch:1> enable Switch:1# configure terminal Switch:1(config)# monitor-by-isid 1 monitor-isid-offset 1 egress-port 1/6 Switch:1(config)# monitor-by-isid 2 monitor-isid-offset 2 egress-port 1/7 map-to-vid 200 Switch:1(config)# monitor-by-isid 3 monitor-isid-offset 3 egress-port 1/7 map-to-vid 201 Switch:1(config)# monitor-by-isid 2 egress-port 1/8 Switch:1(config)# monitor-by-isid 1 monitor-isid-offset 1000 egress-ports 1/1 egress-mlt 16 map-to-vid 1000 Switch:1(config)# monitor-by-isid 7 monitor-isid-offset 7 egress-mlt 2 map-to-vid 203 Switch:1(config)# monitor-by-isid 2 egress-mlt 3
The following table defines parameters for the monitor-by-isid command.
Variable |
Value |
<1–1000> |
Specifies the monitoring session. |
monitor-isid-offset <1-1000> |
Specifies the offset ID that is mapped to the actual monitor I-SID where packets are mirrored. Monitor I-SID = Base monitor I-SID + Offset ID. The base monitor I-SID is 16776000. |
egress-ports {slot/port[/sub-port][-slot/port[/sub-port]][,...][slot/all][all]} |
Specifies the port to which the analyzers connect. |
egress-mlt <1–512> |
Specifies the MLT to which the analyzers connect. |
map-to-vid <1–4093> |
Maps the mirrored packet to a specified VLAN ID for analysis. This parameter is optional. Note:
If you use the Extreme Integrated Application Hosting (IAH) port 1/s1 as the analyzer port on the monitoring BEB for remote mirroring, you must associate it to VLAN ID 4091. |
